Hi.
I have a rambo that I managed to muck up while attempting to use Estlcam controller. i am dangerous enough to F things up, but don’t know enough to fix them.
long story short, i re flashed the board using visual studio with the marlin software, and while it is up, it is set up as an extruder and only one of the steppers work. I did some googling with the code for dual stepper here on the marlin web site for configuration
//#define X_DUAL_STEPPER_DRIVERS
#if ENABLED(X_DUAL_STEPPER_DRIVERS)
#define INVERT_X2_VS_X_DIR true // Set 'true' if X motors should rotate in opposite directions
//#define X_DUAL_ENDSTOPS
#if ENABLED(X_DUAL_ENDSTOPS)
#define X2_USE_ENDSTOP _XMAX_
#define X_DUAL_ENDSTOPS_ADJUSTMENT 0
#endif
#endif
//#define Y_DUAL_STEPPER_DRIVERS
#if ENABLED(Y_DUAL_STEPPER_DRIVERS)
#define INVERT_Y2_VS_Y_DIR true // Set 'true' if Y motors should rotate in opposite directions
//#define Y_DUAL_ENDSTOPS
#if ENABLED(Y_DUAL_ENDSTOPS)
#define Y2_USE_ENDSTOP _YMAX_
#define Y_DUAL_ENDSTOPS_ADJUSTMENT 0
#endif
#endif
but I am unsure how to get it in my build.
do i just copy the text into the appropriate section in “configuration_adv.h” and do a second rebuild?
thanks in advance
