Ryan, you should build one from flexible filament. Then, then you cut at the same feeds/speeds, you can stop all the way Sayers that say it needs to be more rigid.
I have faith in you. You can do it.
Dude…Think it would work? Might dampen some oscillations. The only part I actually question is the XYZ.
Where do you come up with this stuff?
If this new gantry I have been working on works out I think that would be an amazing way to launch it. My first viral video?
I was thinking about it when I was watching Thomas sanlanderers newest video on flex filaments. You should also toss it on the ground, and capture it in slow motion. I don’t know why.
Or run over it with a truck. Apparently that’s a thing when testing flexible parts.
