Also check for cracked clamps, particularly core clamps and z motor. All 3 times mine has gone wonky I’ve found a cracked part. Sometimes it happens during an operation, sometimes during storage (temp fluctuations probably). Checking for cracks is on my preflight list these days.
Also, yes PLA does creep. So it is very possible you may have to reprint certain parts that have creeped beyond spec. This is specially true if it has been stored in a hot area without first loosening key parts (core clamps, z bearings, etc). During summer when my garage often goes above 100F, and I’m not planning to use it for a while, I like to back some nuts off a tad to reduce creep.
Lastly… if the router mount flops around a lot, sometimes it’s possible to get a visual on where it’s moving. Look for relative movement between the core and z tubes, also between the x-y cross tubes and core clamps. Those are the 2 most common areas to see movement. Sometimes seeing it isn’t enough… put a finger between the parts and see if you can feel the movement as you force the router mount around. If you feel any “clicking” or “detent like” action, that’s no good… feeling gradual movement is probably fine.
