Made a hangboard hanger (finger strengthener for rock climbing) with laser etched forest background. Lowrider V2 base, Jtech laser, generic forest google image to inkscape to estlcam. Estlcam has a laser feature but haven’t gotten it to work well yet so just did holes/islands with a tool head of 0.20 mm.
Laser etching isn’t perfect, some lines skipped but there was probably wood crips on the roller path and I was slinging it at 60mm/s with the router still on it. I’m happy with it; no stinkin glowforge could have done it!
You could put some encouraging statements on the bottom of that board as it looks pretty thick. Then, when you’re hanging there and look up, you’d see them
I rented a bike that had a sticker on the top tube that said “pedal dammit”. It was quite encouraging. I only looked at the top tube when I was really struggling. (It was a niner, too expensive to own for me, but a fun bike to rent/demo).
What’s the equivalent? A sticker on the floor. “Hold on, dammit!”?
Good Idea! While I probably could take it off the wall and laser etch the bottom, think I’ll cut out another strip and glue it. Just in case I mess up or the message isn’t received well. “You’re weak if you give up!!”
