Fuel door sticker
My second vinyl cut.
It is evening here now, so the pictures are a bit dark.
You can see the path is almost closed, but the rotating knife (or slightly moving vinyl) caused a bit of a snag.
/walther
Did you use the lead in trick I showed in the walk through. It gets rid of that almost completely.
Forgot about that, I just chose engrave.
I’ll give it a try,
/cheers
