Fusion Post Processor "TinyG"
I have been using the MPCNC_Fusion360_V10_SDcard.cpsand work great,except for when the job is done, the router drops (M18,M84 steppers off?)
I tried updating to, “mpcnc_posts_processor-master” but Fusion says “No Configurations Available”
Looking into it https://cam.autodesk.com/hsmposts? has a “TinyG” post processor , Has any used it?
Is that Guffys post processor? AFAIK, his is the latest and most capable.
https://docs.v1engineering.com/tools/milling-basics/#the-ones-we-have-working
I got the latest mpcnc_posts_processor-master working since I posted this. Ill try it tomorrow. It is from guffy1234.(link on the milling page)
The V10 I was using was from quit awhile ago, and like I said, worked great except the M84 at the end.
PS: My brain is so rattled from reading so much I had to Google AFAIK.lol
I often have trouble with:
IIRC: If I Recall Correctly
AFAICT: As far as I can tell
IANAL: I am not a lawyer
For some reason, I always use them, but don’t recognize them.
Make sure the firmware doesn’t do the m84 command at the end of a print too
I usually use Estlcam. It works fine. I just wanted to learn fusion cam.
Im trying my hand at stacked text and Estlcam was doable, just a little frustrating.
By the way. I used the “master”(the one linked on the milling basics page) it worked great.
Although I can’t find why it says (Dont use arcs)
Arcs work but there is an issue where they sometimes (usually) go much slower than the rest. That’s the only issue and it’s not a deal breaker, just a little annoying, unless you have a ton of arcs.
