Is it possible to load and run any of the firmwares on a plain arduino, like a mega… no motor drivers or anything? I’m working on getting my gcode sender to work with the lowrider and can’t connect to my mini Rambo out in the shed and I don’t want to buy another controller if I can avoid it.
Sure, the ramps setup is an Arduino mega 2560 with a big shield. The firmware works the same if the shield is absent. The shield is ‘dumb’ and just connects the arduino headers to the step/dir pins and big transistors for the heaters, etc.
Excellent… thanks… I’ll try to install it tomorrow.
If you want extra points, you can also load grbl on an uno.
Maslow cnc is grbl-ish so much of the work is done, but I definitely will be working on making it work with true grbl because I know people are working on getting it to work with Maslow.
… hook up LEDs to the pins that would go to the stepper drivers and verify the twinkly lights are getting data
I’ve done this. I hooked up two to the dir pin and one to the step. I was playing around with accelerations and jerk settings.
Yeah, I am bummed that I blew out my development board mega. That was going to be my grbl test platform.
Might try it with my ESP32.
