I’ve been playing around with the dual end stop firmware and a Z touch plate. I can home Z with the touch plate but it does not trigger when using G38.2
I’ve defined FIX_MOUNTED_PROBE and G38_PROBE_TARGET
I’m using Marlin-MPCNC_Ramps_T8_16T_LCD_32step_DualEndstop in version 302 as of today, had the same issue in 301
I have never done it that way I just use it as an endstop. G28 Z. You can then use an offset or add the offset to your firmware. I have the exact details in the basics page.
Yes G28 Z works fine, it even uses the probe offset I’ve defined in M851. I just thought it would be cool to be able to probe in your workpiece, no idea if I would ever need it
Btw I would never have guessed to check the basics page for information on the “advanced” dual endstop stuff, maybe you want to put a link at the end of the dual endstop page…
Yes, that is right you run it like G38.2 Z10 then it moves to Z10 and once it is there it says something like failed to reach location, even tough the probe should have been triggered (it says triggered when checked with M119).
Exactly the same problem with G38.3, it moves to the specified position and fails to trigger, it does not display the error, but that is according to the specification.
How is the touch plate wired to your board? IIRC it should have the two wires on the board at - and S on Z min, and one side goes to the touch plate and the other clipped to your bit.
Yes, I saw that. I only thought it would be easier when updating the firmware in the future to use the config (so that you don’t have to change the code each time).
I did set Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN and then #define Z_MIN_PROBE_PIN Z_MIN_PIN. Which I think is doing the same as changing it in code. At least it gives me probing on all axes.
