So after much work, my Lowrider2 is positioned above the stock. I entered “G92 X0 Y0 Z0.6” and it correctly set the X and Z positions, but Y remained 30. I tried typing “G92 Y0”. Didn’t reset. What am I missing? Is there some work area coordinate configuration that is preventing the Y axis value from being set? Thank you.
Nevermind. I just switched from cncjs to Repetier-Server and the UI was not refreshing. G#d help me.
Repetier host keeps its own track of XYZ. It doesn’t understand G92. You can see the Marlin coordinates with M114. But careful jogging after that. Because RH will send absolute coords based on its idea of zero.
