Somewhere in the internet i’ve read that it’s recommended to have a gap (i think it was 1/4") between the Z rail and the table.
But on the assembly page i don’t find any hint on that.
I think if you have a gap then the lowrider can move in x direction, right?
vicious1
(Ryan)
September 25, 2019, 1:06pm
2
Depends on your table. If it is smooth, sure let it touch. I have it about 1/16"-1/8" from each rail. It is pretty simple to make this change if you ever decided to. I highly suggest you try it both ways and let us know what you find.
The wheels hold it in place not the Z rails.
hmm, but it seems that it doesn’t work everywhere: https://www.v1engineering.com/forum/topic/lowrider-2-sliding-sideways/
i found it: https://www.thingiverse.com/thing:3453813 (LowRider CNC Belt Stop - No Zip Ties)
PS: and yes, my table is smooth
basgoossen
(Bas Goossen)
September 27, 2019, 12:20pm
4
I’ve got a small problem with my Lowrider, nothing that is not fixable, but i wonder if more people have problems with this. On passes in pine wood with a 1/8" 2 flute bit at a feedrate of 1200 and a cutting depth of 3mm. The entire machine has the...
Reading time: 2 mins 🕑
Likes: 6 ❤
In this case i suggest you to read to the end
