So what rails did yall use when building your cnc. Also, what software you use now and is it easy to use on your computer?
Hi there. Here in Norway Biltema 25mm is most common. It all depends on where you are.
I used 1"OD, .083" thickness DOM tubing from Summit Racing.
I started out with the 3/4 conduit, but upgraded to the 1" stainless or DOM. I have both on my Primo.
