First, make sure it turns on and off the router.
If that works, you can change the on/off spindle commands in estlcam and every gcode file you make after that will have the spindle on/off controlled with those commands.
Awesome! Thank you. I will give that a try when I get home in the morning or when I get up in the afternoon.
I refreshed the program and opened the file again. It didnāt give me the same pop up.
Now the question is how do I send it from computer to machine.
Alright so I am connected to the machine but sending M106 is not doing anything. I tried changing the orientation of the connection, I have tried sending just the code and adding it to an existing job. No successā¦ any thoughts?
Buellerā¦
M106 S255 Pxxx
Not just M106, I am not really following this thread very well. Exactly what pins did you connect to (xxx should be replaced by your actual pin number), the link shows 4 pairs. Did you change any numbers in the pins file?
No worries I was just bumping it back to the top.
Itās kind of hard to see but itās the pin set with the peach box around it in the link.
Success!
I looked up the pin number added P2. It didnāt work at first so I flipped the connection and boom it works. Thank you!
So I bought a thing!
Or maybe a thread that may lead me in the right direction?
I have been working on the laser stuff for the last week. It is close but not ready for the rambo yet.
Follow along and there is a thread linked at the endā¦info has been bouncing between the two. Hope to get back to the rambo tomorrow evening or Wed evening.
Awesome thank you
Iām still waiting for this to come in the mail but any suggestions on how to connect this set to the Rambo 1.3 board? Is anything in the set unnecessary or is anything not present?
From what I can see in the picture there is only one red wire. Would it be a simple as connecting the red wire to pin45 and use the external power supply?
Did I ask a dumb question or is everyone just tired of lasers? I have the laser now. I also plugged the external power supply in andā¦ itās definitely a laser. But right now thatās all it is. Just a laser sitting around. I donāt like freeloaders. It needs purpose so I can charge rent.
