Good combo or? The LR3 with SKR V1.3+tmc2208or09
BIQU DIRECT SKR V1.3 32bit Control Board Smoothieboard & Marlin Open
I have this board with the tmc2208 and I also have a set of tmc2209.
I like to use this board with a LR3 with a tft 35 touch screen also from bigtreetech.
I,m a hardware guy not a programmer!
My question is:
  1. What firmware to use?
  2. Does the fw. needs any tweaking to work with above combo?
  3. If so, how to, as simple as possible? Maybe a step-by-step tutorial?
  4. Any other tips n tricks with this combo?
  5. What tmc to use 08 or 09?
Very much appreciate your inputs on this topic!
Regards
“Measure twice, cut once”
MarlinBuilder releases has V1CNC, Skr1p3, DualLR, 2209 version. That should be the right firmware. But it hasn’t been tested. There is a .bin inside that has already been compiled. You should be able to flash it using the sdcard.
If you need to change the firmware, start by building it without changing anything. The firmware source is also in that .zip. You would build it using platformio.
