Grbl Ramps 1.4 duel z & y filmware
Can anyone please help ? Im pulling my hair out :confused:
Ive just built Lowrider 3 but need filmware, I would like to use GRBL so i can use ugs , but cant find away around duel z and y and single x ,
I have a ramps + mega board I would like use ?
a few people keep sending me links to marlin filmware
But really dont want to use this filmware :frowning:
Thankyou in advance
Luke
  • Dual axis motors is only supported on the X-axis or Y-axis. And deletes the spindle direction(D13) and optional coolant mist (A4) features to make room for the dual motor step and direction pins.
Read about it here
I believe GRBL mega 5x will get you there.
ยตCNC Will also be able to do it.
Thankyou ryan however im not sure how to build filmware to add duel z :frowning: can you recommend anyone or any business that can custom build me a Grbl filmware for ramps 1.4 with dvr8825 ?
Thans again
Luke
Thanks for your reply:) however im hopeless at building custom filmware :frowning: I wouldnt know where to start :frowning:
Have you ever used Arduino IDE?
Do you only need dual drive? Do you need auto squaring too? Do you use endstops? Etcโ€ฆ
If you explain your setup I may be able to guide you.
