Are you using E1 for the second Z motor? The second Z port is wired in parallel, which would explain the limited strength.
My guess is you should flash the firmware with the dual version. You can see what you have on the lcd, or with M115. V510S is serial V510DL is dual for low rider.
You can grab the right version at MarlinBuilder releases and upload it with xloader.
