I feel like this is one of those potential “forehead slapping” questions, but I have not found the answer so…
I was drilling multiple helical holes for the spoilboard using gcode generated by ESTlcam. The setup all went fine. The 6 mm bit drilled nice 9mm holes. All that went completely as expected…except…
when the machine moved from spot to spot, it went INCREDIBLY SLOWLY–like it would take 30 seconds to move 50mm.
With normal machining, it doesn’t do this–it moves quickly from one point to another (when not cutting, of course).
What am I missing? Is there a setting someplace for how fast to move when not cutting?
