I’m new to all of this so please forgive my ignorance. I have everything assembled and downloaded but when I’m test the manual movement I get nothing. There is power to all the motors when I test them
I have a PC, I’ve check the baudrate (seemed to be a possibility for the problem). Repetier keeps saying that there are commands waiting.
Is it a problem that each time I plug in the usb Windows is looking for updates from Rambo?
Again I’m a novice so any advice is much appreciated.
Ok thanks! I dusted off that old computer hoping it would work (figured it was a long shot and it seemed to work at first but it was false hope…) After reading up on the XP concerns… I’ll take it to be recycled.
Going to buy a new computer and start there.
Can you tell I’m a novice? Haha thanks for your patience.
Double check your COM port speed setting in Repetier-Host, there shouldn’t be any issue with running on XP, but if you have a speed mismatch they won’t talk to each other. Should be 250000 IIRC.
