We have liftoff!
Sorry for the hiatus from the forums. I wanted to take some time to really investigate, because it seemed less like one big issue, and more like many small ones. And that turned out to be true! Here are the things I found that contributed to the machine working better. Hopefully this helps someone else in need:
Table Squareness
Certain corners of the table were square, but not all of them. The table was actually a rhombus by a handful of millimeters. We took some cargo straps and tightened them until the shape was all square (disassembling as needed), then installed some cross-supports under the table to keep it that shape.
Rail height
The 2x4’s that we used for Rails ended up curving a bit, which meant a slight angle on the edges. We forced them straight and re-screwed them to hold at a consistent height.
Set Screws!
This one is probably the killer. I was demonstrating some of the issues to a friend, and he nudged the roller while the motors were on. I expected it to resist, but it rolled freely, which was a red-flag. Turns out the set-screw on the far-side roller’s X motor had backed itself off over time. I think what’s been happening is that a lowering friction with the set screw meant that the motor would turn 1 revolution, but only turn the pulley part of that. I tried to tighten it up, and found that that specific set-screw didn’t like to be tightened into that pulley. I swapped the set-screw with the Y-motor’s on the carriage, and both pulleys are now satisfied.
Corner Plastic
Originally, I didn’t know how to assemble the Corner-Z and Corner-X pieces together, and as a result, I unevenly overtightened some of the corners. This resulted in plastic warps and cracks where the screws went through. Those cracks loosened the pressure on the tubing, making it more sloppy. One of the zip-tie holes for the X-belt also gave out. Additionally, the warps were blocking some parts of the assembly from lowering all the way. I re-printed the Z and X corners in 100% infill, and re-assembled, making sure to very slowly tighten all screws together. The parts are now unflinching, and I feel a lot more confident that they won’t loosen.
Belt Anchors
The belt anchors also started to crack, largely due to the decking scews I used to put them in. I replaced them metal hooks from Home Depot. I’ll have to add something to keep the belt from shifting around, but these new hooks are super sturdy.
Tightening Everything
Earlier in the thread, I talked about some play that my carriage had. Jeff suggested backing off the MDF screws and tightening the bolts that hold the bearings. This worked great for the carriage, so when we disassembled, I did the same for the Z bearings. Now there’s no play anywhere.
After all that, I ran the test cut, and the skull again, and it looks awesome! There’s a little section that has a step, but it’s about 0.1mm, and I’m happy with that for now.
