I have a question regarding zeroing the machine in repetier. If I type the G92 X0 Y0 Z0 should the cordinates on the screen change to zero or is that more of a machine location? I have been finding zero then disconnect reconnect to get them to show zero but have to hold the Z stepper so it doesn’t drop when disconnected.
Repetier doesn’t ask or trust Marlin for the coordinates, it tries to count at the same time. And for some reason, it does not know about G92. So you can send a secret command @isathome
to force it to think it is at zero. I think you can put that in a macro, so you can have both happen with one button.
