Hi, I’ve got an idea I want to cut, I just can’t seem to figure out what software to use, or how to design it.
I’m trying to create this triangles pattern, is there a way to generate something like this? Or what software should I be using? I’ve installed inkscape but I don’t know where to start.
I didn’t watch the video, but I threw this together in Fusion 360.
I made a base sketch, extruded each triangle up, created a plane from three points, sliced the extrusion with the plane, and deleted the unneeded body. (Repeat 26 more times)
nycnc has some great videos on youtube about fusion paths. You are interested in the 3d paths (2d is for cutout and pockets). After you get your paths setup and simulated so they look good then you need to look into guffy’s post processor for fusion to export marlin friendly gcode.
It’s interesting in the video you linked he uses a downcut bit for the roughing then a tapered ball nose for the finishing. I might have to give that a try sometime it seems like he gets a nice finish and he says it’s about a 1.5 hour cut.
You might save machine time, but I don’t think you’d save time. I would think sanding inside corners and especially the inside vertices would be very tedious and difficult. I think it would be difficult to avoid adding tiny extra facets in the process as well.
I have no idea how to generate the paths in fusion, but I think I would try to avoid or at least minimize sanding on something like this.
