Hi guys I have problem with one part
[attachment file=44593]
problem for me is machining this slot without overacting corners I try to make it in Estlcam but its look like its not cutting all the way.
Can you give a screen shot? I think I know what you mean but need to be sure, or zip and upload your .e10 file.
Yup, this is what you mean correct?
[attachment file=44608]
You need to over cut it. Let me update my estlcam and I can show you.
He shows it here, you manually make a the pocket larger, the first time might be a bit confusing but once you get it, it is simple.
deam i was not knowing that i can go out from the drawing like that. Like always Thanks Ryan.
