Hello, everyone, i need some help with using / cutting on the cnc. i created a simple circle gcode using vetric aspire and it worked perfectly. i used the exact same settings when generating some new gcode but when i when to run it on the cnc it started burning the MDF instead of cutting it so i tried increasing the rpm of the Makita router i am using and that still did not work and the stepper motors where unable to move the X or Y axies when cutting. This problem keeps coming up i find some settings that work (15 ipm, 2mm DOC, 3mm Plunge rate) and then i go to use them for another thing and it just ends up burning the mdf and making the machine lose steps. Can anyone explain to me why it is not working?
My original Cut
What I’m trying to cut
