Hi. My MPCNC Primo has started acting up regarding homing the z axis.
Sometimes, it will home as it should. Other times and more often, it will raise the z axis a few mm when I press the Home Z button in Repetier host.
I checked the limit switch conditions with M119 and they are all reading open.
I flashed the latest firmware to the board using XLoader and the hex file downloaded from the V1 site.
I saw there was another post on the forum where the OP said his power supply was the issue. What can the power supply contribute to the issue - electrical noise maybe?
I also tried with the router (Dewalt) disconnected from power and that does not resolve the issue.
The output from the M115 command is below:
11:29:16.951 : Printer reset detected - initializing
11:29:16.951 : start
11:29:16.951 : Marlin 513D 2.0.9.2
11:29:16.955 : echo: Last Updated: 2021-09-03 | Author: (V1 Engineering, Ryan, 513D)
11:29:16.955 : echo: Compiled: Oct 24 2021
11:29:16.959 : echo: Free Memory: 3386 PlannerBufferBytes: 1488
11:29:17.162 : N1 M11034
11:29:17.162 : N2 M11536
11:29:17.162 : N4 M11435
11:29:17.172 : N5 M111 S698
11:29:17.175 : N6 T060
11:29:17.175 : N7 M2022
11:29:17.176 : N8 M8019
11:29:19.962 : echo:DIGIPOTS Loading
11:29:19.962 : echo:DIGIPOTS Loaded
11:29:19.970 : echo:DIGIPOTS Loading
11:29:19.970 : echo:DIGIPOTS Loaded
11:29:19.974 : echo:V85 stored settings retrieved (596 bytes; crc 60833)
11:29:23.969 : N9 M220 S100104
11:29:23.969 : N10 M221 S10081
11:29:23.969 : FIRMWARE_NAME:Marlin 513D 2.0.9.2 (Oct 24 2021 13:38:47) SOURCE_CODE_URL:github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:V1CNC 513D EXTRUDER_COUNT:0 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
11:29:23.969 : Cap:SERIAL_XON_XOFF:0
11:29:23.969 : Cap:BINARY_FILE_TRANSFER:0
11:29:23.972 : Cap:EEPROM:1
11:29:23.972 : Cap:VOLUMETRIC:0
11:29:23.972 : Cap:AUTOREPORT_POS:0
11:29:23.972 : Cap:AUTOREPORT_TEMP:0
11:29:23.972 : Cap:PROGRESS:0
11:29:23.973 : Cap:PRINT_JOB:1
11:29:23.976 : Cap:AUTOLEVEL:0
11:29:23.976 : Cap:RUNOUT:0
11:29:23.976 : Cap:Z_PROBE:0
11:29:23.976 : Cap:LEVELING_DATA:0
11:29:23.976 : Cap:BUILD_PERCENT:0
11:29:23.980 : Cap:SOFTWARE_POWER:0
11:29:23.980 : Cap:TOGGLE_LIGHTS:0
11:29:23.980 : Cap:CASE_LIGHT_BRIGHTNESS:0
11:29:23.980 : Cap:EMERGENCY_PARSER:0
11:29:23.980 : Cap:HOST_ACTION_COMMANDS:0
11:29:23.984 : Cap:PROMPT_SUPPORT:0
11:29:23.984 : Cap:SDCARD:1
11:29:23.984 : Cap:REPEAT:0
11:29:23.984 : Cap:SD_WRITE:1
11:29:23.984 : Cap:AUTOREPORT_SD_STATUS:0
11:29:23.989 : Cap:LONG_FILENAME:0
11:29:23.989 : Cap:THERMAL_PROTECTION:1
11:29:23.989 : Cap:MOTION_MODES:1
11:29:23.989 : Cap:ARCS:1
11:29:23.989 : Cap:BABYSTEPPING:0
11:29:23.989 : Cap:CHAMBER_TEMPERATURE:0
11:29:23.993 : Cap:COOLER_TEMPERATURE:0
11:29:23.993 : Cap:MEATPACK:0
11:29:23.993 : N11 M111 S687
11:29:23.993 : X:0.00 Y:0.00 Z:0.00 Count X:0 Y:0 Z:0
11:29:23.993 : N12 T0*9
11:29:23.997 : echo:DEBUG:INFO,ERRORS
11:29:23.997 : echo:No media
11:29:24.001 : echo:Unknown command: “M80”
11:29:24.001 : echo:Unknown command: “M221 S100”
11:29:24.001 : echo:DEBUG:INFO,ERRORS
I’m using the V1 mini touch plate. Rambo board with dual end stops (purchased from Ryan). All axes move in the correct directions when jogging with Repetier and it cuts fine when I can get the Z axis to zero correctly.
In other cases, I’d just move on and zero it manually, however, this project has multiple passes with different tools and I want the bottom of the cuts to be at the same height.
Is there a sequence I need to follow before homing the Z axis? As in, do I need to home the x and y first? I’ve been using the machine off and on for a year or two now and I’ve never encountered this issue.
