Or would it be a huge project to try and undertake? I don’t know much about ZBrush and all that but if it’s relatively trivial then I’d start learning and taking a crack at it. But if there’s just not enough data then I won’t waste my time.
I’m willing to bet that if you used a lithophane image processor on those but carved them flat you’d have a pretty respectable result. Might not be spot on but the way the greyscale in those look to me it looks like it might just work without having to model.
There is a low budget version of Z Brush out there and it’s not a HUGE learning curve but the amount of detail in these doors - they must have taken the dude forever to do.
Post #17 has the magic in it. Those greyscale images are height maps. Process those and you have perfect STL file to carve. The two with the black to white ramp to the right of them. The images are about 13 inches tall if you download them. You could process them up a bit but not to door size. And to be fair I’d ask the original contributor if it’d be OK if you played with the images first.
I wonder how he gets around the copyright. There’s a carver here that’s done some outstanding things but all in direct violation of copyright. Drives me bonkers.
I’m willing to bet the height maps on the second page will do it with the right heightmap processor. If I have some shop time in the near future I’ll run one and see. It’ll be fun to get myself all excited about being able to do it but still needing to ramp up the ZBrush skills first. Hahaha
As for copyright legal issues you don’t have to worry about any of that if it is for personal use. In fact, technically, once you change the medium (from a picture to a 3D image) you have altered the original to make it your original. After all, you are sculpting now. Bronze and marble statues are created under the same premise. Hope the vids help.
I just might make the lion one myself. That’s pretty cool.
FYI, the first two programs are free downloads. Blender is for sculpting the image. Inkscape is for converting file types.
Blender, Inkscape and Illustrator are great to convert images into SVG (scalable vector graphics) for 3D carving files. Once converted to svg, it can be converted to the STL file format, which can be converted into gcode.
I missed this the first time. One thing I noticed:
In the first images, you can see that there is a light source. So the top edges are bright and the bottom edges are shaded. That is going to make it impossible to recover the actual height from the renders. You can use images like that to get a reference in XY, but you’ll have to figure out your own Z. In the later images, you can see Z represented by intensity. Those, you can use.
And as far as the copyrights. This person made new art in zbrush. Yes, it is reminiscent of GOT, but it doesn’t use their logos, characters, or anything specific to GOT. If you used them from this post, even for personal use, you would be violating that person’s copyright. Even if you converted it to stl. That is still not ok. It wouldn’t be noticed, or enforced, and many people would like to see their work copied. But it sounded like this person did this work for a company (mentioned their boss). Their company probably owns the copyright on these door images.
Just want to convert pictures not copy his not a fan of whatever they came from . Yes he was commissioned to do that from what I read using zbrush I just want to take Garfield from the laser thread and use him or my own.pic.
