sngehl01
(sngehl01)
July 3, 2019, 10:59am
1
Ordered my MPCNC and meant to add more belt to the order.
I tried viewing the page for how much belt I need. The page doesn’t appear to be working though. The belt I received is good for 48" of total x+y, I’d like to do 2 ft by 3 ft.
https://www.vicious1.com/assembly/conduit-rails-tubes-pipes/
Ryan’s shop sells them in 2m lengths… that along with what came with your kit should work for you. Easier on Ryan, too
sngehl01
(sngehl01)
July 3, 2019, 11:55am
3
Thanks, that’s actually what I was going with and thought it wasn’t going to be enough.
In my mind I was taking 13’ / 2 = 6.5’ needed each for x and y… which is right, but I forgot it’s on each side.
So the extra 2m will be more than enough. I didn’t have my thinkin cap on. Thanks
Where did that link come from it is an old one, it should be @ v1engineering.com
sngehl01
(sngehl01)
July 8, 2019, 12:17pm
5
Ryan - it came from here:
Parts bundle for Mostly Printed CNC
This works with all 3 versions (23.5mm, 25mm, 25.4mm).
*You will still need printed parts, conduit, and a spindle.* *optional but recommended is an LCD as well for headless use*
Options; The control...
Price: USD 207.00
Clicking “conduit” in the parts you’ll still need section.
Thanks. Fixed the links, redirects are getting treated poorly.
