How to copy a section from PDF drawing and convert to DXF
Hi
I should have my MPCNC up and running in the morning(Happy days) and the reason I built mine was I make and fly(or at least try) RC aeroplanes.
I prefer to make mine from plans that I print out from PDF files. hear is an example. http://www.outerzone.co.uk/plan_files_07/7352/Aerogull_plan.pdf
If you look at the bottom right corner you will see the wing rib template.
How, What software would I need to use to cut/copy just a section form the PDF plan and convert into DXF file so I can use Estlcam to send to the CNC?
As always you help is much appreciated( and iv had a fair bit so far)
Thank in advance
Chris
Aerogull_plan.pdf (1.57 MB)
