How to insert belt into tensioners?
Hello,
I’ve almost build my MPCNC primo but I’m struggling with belt tensioner.
I’m not able to insert belt into them.
What did I miss ?
Do you have any advice ? Issue with belts thickness?
Thanks
Can you give us a picture of how things look like atm?
Sure, here it is.
Not sure if it can help.
Thanks
Press hard. I used a screwdriver for it and pushed it in. Took quite a bit of force.
The belt looks a little thick? Is it from Ryans shop? I’m at work, I’ll take a look when I come home how it looks.
+1 A liberal amount of gorilla effort and a flat-bladed screwdriver. I used a big screwdriver and used it more like a press.
The belt come from Aliexpress not Ryans shop.
From here : https://fr.aliexpress.com/item/32811217193.html
Ok, I will give it a try without cutting my fingers :smiley:
Thanks
The last pic is how you should insert it. Make sure the teeth are meshing. If there are any burrs on the print, remove them with a hobby knife or a lighter.
Almost!
Now stab it with the edge of the screwdriver. That’s what I did. :slight_smile:
