Hello,
I’m almost ready to make the first test with the laser from 5.5watt bought last month …
But before you make the first test on my mpcnc wanted to ask about the use of cnc as lasercutter what puts the material to be processed as protection …
I’ll explain:
if you need to cut a small panel of 4mm below I recommended to the panel material to place in order to protect the main floor of my cnc?
I await your advice, I thought to a metal plate 2mm
Thanks !
Have a Nice day
