Ryan - you’d be awful proud if you could see me now. Hahaha…
I think I’m ready to start trying to cut some wood here. I was watching a test run in foam and couldn’t help but wonder two things. First, does the awe of watching the MPCNC run ever go away? And second, more on point - is there a table or chart out in the webiverse somewhere that lists feed rates and plunge rates for given types of woods? Or is it too variable due to the wide range in bit diameters, spindle speeds etc? What’s the “cautious” approach on feed rates? Is it the “For the Impatient” in the Basic Info stuff?
Also - I was looking through the bits in the store and those on Amazon (I had to order a fresh set of ice carving endmills today…the season is coming up soon…so while I was doing that I popped over to Amazon and v1Eng to have a look at the wood CNC bits). There surely must be a semi precise way to facilitate tool changes without going to the dual end stops, no? I was thinking an adjustable pedestal that you can screw/unscrew to different heights such that you slide the bit into the collet, slide the pedestal under, let the point of the bit rest on the pedestal while you carefully tighten the bit in? When the time to change comes you just do the same with the next bit? Any reason why that wouldn’t work with some degree of accuracy?
Then lastly - to really convolute this thread…what sort of bit collection “should” I be building? Short, long, ball nose, flat,
