Getting this error in X axis. Typically on the first bit of the first cut. I cut out 2 identical things for one of my kids, long in Y and short in X. First example returned this photo.
So it seems to be dragging the router down the Y axis correctly but comes in from the side as if the router has not traveled far enough in X first.
Or is there some software setting that could be funny before I pull it apart?
Looking at Picture 1. It appears that you plunge cut at your finger and move left. If this is is true then I think your plunge rate is a little fast. My reasoning is because I see you have the same offset at the web on the other side. But as noted by others, may just be the camera. If this was done in 2 passes. Looks like the first plunge is not the same depth as the pass ended over the web. To much pressure and the bit ‘walked’ to the softer side.
Running into a dense bit of material, and a tiny skip and now the cutting is shifted too.
What are the feedrates and details you were working with? I assume most of us have run into symptoms like this before. Aside from grub screws, often it is overly aggressive feeds. Curious to hear the solution you find.
