setPrintPos
sketch\src\lcd\dogm\lcdprint_u8g.cpp:39:23: error: ‘ret’ was not declared in this scope
u8g.setPrintPos(x + ret, y);
sketch\src\lcd\dogm\lcdprint_u8g.cpp:39:23: note: suggested alternative: ‘reti’
reti
sketch\src\lcd\dogm\lcdprint_u8g.cpp:39:28: error: ‘y’ was not declared in this scope
sketch\src\lcd\dogm\lcdprint_u8g.cpp: In function ‘int lcd_put_u8str_max(const char*, pixel_len_t)’:
sketch\src\lcd\dogm\lcdprint_u8g.cpp:45:24: error: ‘class U8GLIB_ST7920_128X64_RRD’ has no member named ‘getPrintCol’; did you mean ‘setPrintPos’?
unsigned int x = u8g.getPrintCol(),
setPrintPos
sketch\src\lcd\dogm\lcdprint_u8g.cpp:48:23: error: ‘ret’ was not declared in this scope
sketch\src\lcd\dogm\lcdprint_u8g.cpp:48:23: note: suggested alternative: ‘reti’
reti
sketch\src\lcd\dogm\lcdprint_u8g.cpp:48:28: error: ‘y’ was not declared in this scope
sketch\src\lcd\dogm\lcdprint_u8g.cpp: In function ‘int lcd_put_u8str_max_P(const char*, pixel_len_t)’:
sketch\src\lcd\dogm\lcdprint_u8g.cpp:53:24: error: ‘class U8GLIB_ST7920_128X64_RRD’ has no member named ‘getPrintCol’; did you mean ‘setPrintPos’?
setPrintPos
sketch\src\lcd\dogm\lcdprint_u8g.cpp:56:23: error: ‘ret’ was not declared in this scope
sketch\src\lcd\dogm\lcdprint_u8g.cpp:56:23: note: suggested alternative: ‘reti’
reti
sketch\src\lcd\dogm\lcdprint_u8g.cpp:56:28: error: ‘y’ was not declared in this scope
sketch\src\lcd\dogm\u8g_dev_st7565_64128n_HAL.cpp: In function ‘uint8_t u8g_dev_st7565_64128n_HAL_fn(u8g_t*, u8g_dev_t*, uint8_t, void*)’:
sketch\src\lcd\dogm\u8g_dev_st7565_64128n_HAL.cpp:154:29: error: ‘U8G_SPI_CLK_CYCLE_400NS’ was not declared in this scope
u8g_InitCom(u8g, dev, U8G_SPI_CLK_CYCLE_400NS);
