@jeffeb3, got a newbie question on lasers, MarlinBuilder and maybe Plaform.io.
I think I generally understanding how the MarlinBuilder works in generate the nightly V1 Engineering specific machine builds from Marlin bugfix. BTW, nice use of Actions.
Its clever how the MarlinBuilder is doing opt_set and opt_add in order to avoid the confusion of having to edit multiple Marlin files directly (though I need to figure out the difference between an opt_set and a opt_add).
While looking at the laser code changes in MarlinBuilder for the SKR PRO I can see you doing the following in MarlinBuilder/src/configs/boards/skr_pro.
opt_add SPINDLE_LASER_PWM_PIN PC9
My question is, “Don’t you need to also undefine SERVO1_PIN which is defined in pins_BTT_SKR_PRO_common.h so the is not a conflict in using PC9”?
// Servos
#define SERVO0_PIN PA1
#define SERVO1_PIN PC9
After reviewing most of the servo code I was unsure if the servo code was getting included just because that pin was defined. BTW, I can easily be convinced I’m wrong as I’m just starting with Platform.io and how it all pulls back together before doing the build.
