Hi,
Completed my first build and now looking for some help –
- Did you buy everything from here? No –
a) 5 NEMA 17 stepper motors using RAMPS/ARDUINO combo flashed with “Marlin RC7 MPCNC w/LCD” downloaded from here. No LCD currently. Controlling via USB. - No end stops
- PC
So far I have been able to control the router manually with Estlcam, and send gcode for plotting. The dimensional accuracy of the product though is quite inaccurate. The X/Y direction seems to be doubled in size, while the biggest issue – the z axis is moving but very little. It moves quite freely/quickly when I manually control it via Estlcam so I don’t think binding is an issue. I can move it through its full range. E.g., For a 10mm Z movement in ESTLCAM, the z axis moves about 1 mm. I set it for a 5 mm depth cut and by the end of the gcode, its Z depth has only minimally changed despite the software stating its now 5mm deeper.
Unfortunately I’ve been unable to connect with Repetier-host to test my set-up with different software. I’ve tried multiple baud rates, two different computers, and re-flashed the stack multiple times. I’m now getting a MAXTEMP error/Kill command which I can’t seem to solve.
Thanks for any input!
