Hi,
Almost done putting my MPCNC together.
But when I start a gcode-job, it starts by moving the Z-axis a few cm up ?
After it is moved up, it moves up and down according to the clearance specified in the file.
I can not find the command in the gcode that would do this.
I have tried different combinations of software.
Any thoughts ?
(In the attached file I would expect an initial movement of 1cm up, and then 1.1 cm down later. Instead it moves 3cm up, and then 1.1cm down and up, and finally stops 3cm up)
abc.gcode_.txt (4.97 KB)
