I’m trying the Inkscape to Estlcam to Repartier workflow. I’m new to Inkscape and Estlcam and in trying some experiments got unexpected results.
One example: I use a feature in Inkscape to modify a primitive (like to change a rectangle to a rounded rectangle) and when I open the svg in Estlcam it displays the primitive shape (a square cornered rectangle).
I’ve had multiple cases like this tonight where what I draw in Inkscape and what displays in Estlcam don’t match.
Is this the result of a setting or one of a set of bugs / interactions between the two packages that are already documented somewhere?
I’m sure I could work around it by drawing 4 line segments and 4 arcs. The reason for the question is whether I need to always be looking for this kind of issue and expect needing to rework geometry or if there are some Inkscape features I should avoid using because they have known issues when Estlcam is the next step.
Thx
