I think I am close to finishing my build of the LR2. I’ve built my table, and assembled the hardware and plugged in the electronics.
I have had difficulty finding information about the LCD. I can turn the knob and that seems to work, but I cannot figure out how to do anything else (besides hitting the reset button). I saw a video of someone using the knob as a button, but when I press the knob nothing happens. If it helps I have uploaded a video showing this: https://youtu.be/4ulV1lPaXwU
Is the knob suppose to be a button too? If so, what could be wrong and how do I fix this? If not, how do I make selections on the LCD?
the knob is interfering. You can pull it straight of and try just the metal part of the knob.
something is wrong with your lcd. Everything is independent, so it’s possible a bad solder on the lcd would leave the button broken and everything else fine.
a wire between the lcd and the controller is broken. This seems like the least likely. But you could inspect the wires.
