Is using different settings on the tool list during the same cut possible?
I made 6 rectangles today on Aspire and opened them in Estlcam. I then made 6 different tool settings and selected one for each rectangle to test out some new settings. I found that it would only cut one rectangle, go back to home, and stay there like it’s done, but Repetier says it isn’t complete. Can different settings not be used for the same cut? I could have sworn you could do this.
Sounds like there a tool change in progress and the LCD probably says something like: “waiting for user input”. You can click the turn knob on the LCD to continue or change the settings in estlcam to delete the M0 on a tool change.
Okay, I’ll plug the LCD in and see if it says that. Thanks.
That was the issue. Thanks.
