Hi,
My MPCNC survived it’s first power up and after switching the stepper wires around everything is moving in the right direction and the end stops are doing what they should…Control is working vi both PC and graphic board.
A fairly standard build with a work area 2 feet by 2 feet by 4 inches. Have mounted it on a solid bench I made of 2 x 4’s. Will spend today working through getting it to draw the crown.
Still have to tidy wiring, print a case for the Rambo board, the work through offsets for the end stops.
Pics to follow…
cheers
Gary
Australia
