The instructions for the MPCNC says conduit but the instructions for the LowRider2 say specifically not to use conduit. It this accurate? My local hardware store has plenty of conduit but no pipe. Does anyone know why conduit wont work?
Thanks
Thanks
The plastic parts only come in sizes that fit 25mm (foreign common pipe diameter) or 25.4mm (domestic 1" pipe diameter). My guess is that because the lowrider is designed specifically for large format, and that the X axis will be quite long, that regular EMT conduit would be to flimsy. Therefore it only comes in sizes that support heavier-duty, larger tubing sizes.
Finding steel is probably easier than you think that it is, but youâre not likely to find it at Home Despot, or the big box stores.
Google âSteel tubeâ and your city, and youâre likely to find a few places around that will sell you some. It can be quite a reasonable price, if you find the right supplier, though some people have only found somewhat expensive suppliers.
Jegs and Summit have 1" stainless steel, intended as roll cage bars for hot rodders, and will deliver.
If you find a good wholesaler, you should be able to find it under $1/foot. (I work for a steel wholesaler, and that would be the âguy walks in off the streetâ price, in a 20â length.)
I have a conduit mpcnc burly 1x3 and a lowrider 4x8. The SS tubing is far superior.
The emt works for the small spans in the mpcncs but at 3ft I can see deflection even with the lightweight core. If I build a primo Iâd use SS for it as well.
The lowrider carries a heavier router assembly across a longer 5ft span. Even with SS there is a 1-2 mmm sag from edge to center.
There may be a cheaper solution to SS tubing on the lowrider but emt isnât it.
I will add, finding a steel supplier nearby and asking if they have or can get â1â DOM tubingâ worked for me. They got some 0.125â wall for me in a few days⌠enough for my primo and then some, for under $100.
FYI, pipe is measured from the inside, tubing is measured from the outside, so in your hunt for metal for your LowRider, you are looking for 1" tubing (or 25mm tubing if in Europe), not pipe.
This isnât right. Careful. 1" tubing, not pipe.
Exactly.
Ahh, tubing, my mistake.
Iâm using curtain rod welded steel tubing from Home Depot. Itâs 1" exactly. Very straight and very stiff. Thin wall. The telescopic kind.
They come in 50" length, you throw away the smaller inside tube. Just align the tube so a bearing doesnât run on the weld if that bothers you. I had some in the garage after a remodeling project so the price was free.
My LowRider is only 36", not the full 48 but I canât see any deflection.
My only complaint is that they are coated with some clear shellac or varnish that is wearing off on the bearings a little.
If you are lucky, your wife may not notice, and for a bonus you can add nice finials on one end.
Tom
Thanks, that makes a lot of sense
Thanks, Iâll have to look again. I found a supplier that wanted $100 for 6ft of tubing which seemed really expensive
I googled steal tube in my area and called several places but didnât have much luck. The best I could find was galvanized steel tubing. I donât suppose you know if this is any good? It would cost me about $100. Or would I be be better off ordering the DOM from Amazon for $60?
IIRC, the galvanization process leaves a⌠suboptimally smooth surface on the tubing which also has a tendency to flake off. It can be removed vis lathe (including the expedient effort of rigging up a drill and some bearings for support), and sanding the tubing smooth. Of course, then you have all the fine zinc galvanization dust in the air, and thatâs some nasty stuff.
Your best bet is to order some from a metal supplier rather than Amazon. Metal Superstore(?) is one I hear frequently. You might also try asking at a welding supply company. They may not sell steel tubing, but they may know where to get it.
Thanks for the response. It seems my area just doesnât have much in the way of suppliers. I will keep looking though. Thanks!
