I started with the table to get a good base for the Lowrider V2.
The depth of the built torsion box is 8.25 inches.
Four full size 3/4" sheets of MDF later, I have a sturdy (and heavy base).
(The leg leveling kit off Amazon is awesome)
I’m using full sheets of MDF top and bottom and using them as a reference for the torsion box and side rails.
The side rails are (2) 3/4" BB ply strips with channel strut bolted on.
The side rails are slotted at the ends (to allow vertical alignment) and through bolt to brass threaded inserts into the torsion box (each side of the torsion box is double thick).
I know I need to brace the legs (and will), but this is rock solid as is.
Pics attached and will post when I get the rest assembled.
If someone just made some sort of bowflex machine that worked as a generator or something…That way it wouldn’t feel like lifting weights wasn’t just for vanity. Million dollar idea #24581.
I think I’d want it shorter, and I want the pipe rests deep enough there’s no chance of it being misaligned. I would also have some starting gcode to lift the gantry up on startup. I’m getting more convinced all the time that adjustments are the devil, and I just want it bolted down in the right place from the start. But I can see how it`s easier to adjust it than the whole piece of unistrut.
This is a big win for unistrut, IMO. Thank you for sharing.
I guess I could actually make one that’s just an inch tall, and screws down from the top to my spoil board. Then I’d just have to cut a hole in the spoil board under the resting position to make room for the bit.
Shorter would be nice, but I really want full sheet capacity. So I need the front cutout for work on this end.
The ones I just cut are taller than the ones in the pic.
The divots are 126mm apart, and I used a diameter of 26mm (25.8mm in the STL model).
I think with a horizontal L bracket, I can reference off of the top of the unistrut, and then the edge of the MDF top.
Perhaps we are overthinking it, and all we need is a L piece with divots, and the short leg hangs over the edge of your top.
Dogbone that inside corner, don’t screw it down, then it can be a removable home/rest reset! (and you can make it tall enough to not hit your tools. (I had a jig like that for my first 3d printer…)
