Looks like it keeps load constant , per description “when the motor of the drill machine is slowed down by the resistance of the drilled object, the counter-EMF of the motor also decreases. This results to a voltage increase in R2-P1 and C3 causing the triac to be triggered earlier and the speed increases accordingly.”
I know “Super-PID” is awesome but WAY over my (ok, my wife’s) budget.
Hi…I have a SuperPID waiting to be installed, but have not done so yet as there were other problems with the machine, they have now been sorted.
The SuperPID uses an optical sensor mounted in the case of the router. There is room as the existing speed control is removed. This means that the spindle must always be used with the superPID as otherwise all nasty things will happen, like overspeed and burn-out.
