Hi all! I’m finishing my MPCNC Primo, I’m looking for a good Kress tool mount. Does anyone has an STL file for that tool mount?
Thank you very much!|
Best regards
Simone
Best regards
Simone
I am pretty sure there are some on Thingiverse or Prusaprinters. Try searching “kress MPCNC” or more specifically “kress Primo”
Thank you very much! Can I use the old version Tool mount plate on the Primo?
Yes you can. To mount the plate you can use Burly nut traps and the smaller machine screws, or you can print the mounting plate with some extra perimeters, drill out the holes and use the Primo nut traps and the larger machine screws. Which Kress tool do you have? What mount on Thingiverse are you going to use?
Kress is AMB nowadays:
MPCNC Primo AMB 1050 FME 43mm tool mount by Antigreen | Download free STL model | PrusaPrinters
