I’ve seen some large diameter E3D Volcano nozzles being used and wondered if anybody who has used them had thoughts to share, or if they are available for the MK8. If they aren’t available for the MK8, I’d like to turn some on the lathe and see what happens. Maybe send a few freebies out for testing
I’m thinking somewhere between .6mm and 1.2mm, although 1.2mm seems a bit much for the MK8. I’ll turn them from 6mm or 8mm brass hex stock and plan on threading them M6. I guess stainless nozzles can happen later if these work out. Since I don’t have any experience using a stainless nozzle, I don’t know if they are even worth the cost and effort of researching which alloy to use. I’ll probably order the stock and tool steel that I will need on Saturday anyway.
Thoughts on design? I’d like to experiment a bit and see if there isn’t a way we might do nozzles differently. Like inside bore taper angle at the tip, or edge shaping of the hole on the outside of the nozzle.
