Hi all,
While I’ve been 3D printing for years, I had always wanted jump into CNC. However, cost was prohibitively expensive at the time. I currently have a budget of $1000 and was almost about to purchase the Maslow, before I learned about the LowRider2. Based on what I see, I like the setup better than the Maslow. I’ve also heard that the Maslow tends to have accuracy issues and it is not a good option for any sort of carving. I don’t foresee doing a lot of carving or projects requiring laser-sharp accuracy, but if the LowRider2 can provide better accuracy and carving functionality, even better.
Has anyone been in the same situation where they were contemplating the Maslow and ended up going with the LowRider? If so, are you happy with your choice (or not)? I am sure I won’t go wrong with either CNC kit, but money is tight and looking to make the most informed decision possible.
I’ve heard of “wobble” issues with LowRider, is that mainly due to user-build error or does this issue exist? I am assuming if you have a sturdy enough bench/table, there won’t be any “wobbling”. I had a “wobble” issue with my 3D printer, but it was all due to the flimsy table it sat on, is this similar?
Anyway, thanks in advanced!
