Ryan has done an amazing job developing the tolerances for these machine. I was a little surprised to see such a large gap between the upper z support bearings closest to the wheel. Is this normal?
Edit: I’m just a big dummy and was looking it over before I put the other pipes in. They will cause it to shift over.
No not at all. Actually you do not even have a gap as shown in the instructions on your Z and XZ mains. So either your prints are bad or you have the wrong size pipe, or you have severely over tightened the parts…or you forgot the spacers?
Your completely correct! Once I get the other pipes in everything will shift over. Thanks for the quick reply!
