It worked but my y axis was 1/8in out of square which turned into 1/4 total offset between the rear machining and the front. It’s not scrapped, just cant be used as a guitar because everything is misaligned. It looks good, until you attach the neck and see how crooked it is.
Well the timelapse didnt work out. Too many photos not enough card. I’ll work on that since I am cutting 2 of these.
Back side done. Flipped and the 4 pins lined up perfectly this time, I have high Hope’s.
I’m not sure what’s going on, but the last step when I went to start it, I’m getting electrical interference on the y steppers when I move the knob or click on the control box.
It sounds like the stepper is moving but it seems it’s just chattering in place. At least i hope it didnt move or this will be out of wack.
Would you mind sharing a few more details about your project? i.e. CAM software? bit(s) used? How exactly you indexed it when flipping the blank over to carve the 2nd side?, etc. Sure would help a newb with a snazzy new V1 machine and similar aspirations of guitar glory.
