Line is not straight
hi
I have a lowrider and makita router and skr1.4 turbo card.
when i need to cut un straight line, my line have a light curve.
i check my step x and Y and all is very good. when i move axe 300 mm i read 300mm on each axe.
can you any idea to my problem?
A few things to check: belts, loose core, deflection.
  • If you used steel core belts, the steel will eventually break resulting in belts that stretch unevenly.
  • A loose core will move under force and may wander in a semi-predictable way.
  • If you drive the router too hard, you will see bit deflection.
Check the core first. While not powered, just rotate the router around the X and the Y axis to see how much play you have, and how much force you need to apply to get it to move. Next use a pen mount and draw squares of different sizes and starting at different positions. Verify the size, straightness and squareness of the squares. Repeat the drawing run starting from the same position and verify that the lines match.
Also which axis is not straight? Is it Y or X or both that have the issues?
thank’s for your help…my problem is so stupid. my endmill is bad.
i change that for a new one and raise a little speed and all is correct.
