Hello there! I am at the stage where I’m deciding what the exact dimensions for my setup will be. I’ll start with my first of two questions…
On the calculations page to determine lengths, is the belt length a finalized number, in other words does it account for the loop around the tensioning point on both sides with a little bit extra for safety, what have your results been, I’m trying to cut it as close as possible with the uncut belt length i possess.
Second question…
I want to have my working area 20" by 50" so that i can cut out long airfoil wing profiles with plasma. These can have a 1/5 - 1/9 height/length ratio. A long length like that would certainly have problems when using a router. I was going to wire the steppers in series off a single driver and make sure the wire run lengths are identical. Also I’m assuming that the shorter nonflexing 20" side in addition to adding more supports on the 50" lengths would be enough to keep the cuts precise. So with the series wiring and supports… am i going to have any foreseeable problems. Am i missing anything?
Hoping to overcome warp with a liquid feed.
I look forward to reading your replies… thank you in advance for your input!!
