Hi gang, as I get used to my LR2 I’m trying to optimize speeds and feeds etc.
My x-axis can plow through pine with 7mm DOC at 1500mm/min with a 6mm 4-flute upcut flat endmill, but my y-axis is losing steps (sometimes, but it only takes once to ruin a job) at even 900mm/min. My router is quite happy at these speeds. My chips are about 1mm wide.
Is this simply because X has two motors and Y has one? I turned up the current on my Y a little which helped, but I guess not enough.
What speeds/feeds do you typically use with softwood? Am I just pushing too hard?
I notice that even though I chose “conventional” milling is ESTLcam, is seems to use the same stepover in both directions when it is doing back-and-forth cuts.
If this is just a case of less power in Y I might just write a post-processing script to reduce feeds in that axis only.
At the top I was losing steps in Y all over the place. I was definitely pushing too hard ~1500mm/min
Was still pushing too hard I guess ~ 1200mm/min but I was great until it hollowed out the “O” and then it lost Y steps. Full 7mm DOC
Then I thought I’d focus on speeds and feeds. On the 9 3/4 circles right to left, when using a small step downs, say 2+2+2, on the second pass the Z would take a dive right through the material. Then I switched to a single 7mm DOC and the left two are perfect.
Down to about 800 mm/min. All perfect until hollowing out the letters, lost Y again.
Now I’m down to a crawl ~450mm/min. Lost X and Y.
For #1-3 my driver voltages were about 1.1, 0.85, 1.1
For #4 my driver voltages were about 1.1, 1.1, 1.1. 6mm DOC
For #5 I brought them all down to 0.9. 4mm DOC
This is all with a very sharp endmill and a 6.5A router.
Below 0.9 I find I can give them a little poke with my finger and they lose steps but keep in mind that my router is a little heavier than yours. So it seems like on the low side they just can’t push and on the high side I’m probably getting thermal shutdown !?
I was thinking tomorrow I’d try 1mm DOC just to rule out forces vs. stepper drivers.
That is nuts. That is a large endmill, and 4 flutes. I have no idea how you are getting nice chips. Try to find a single or two flute at the most. With high RPM routers 4 flutes is a very very bad idea. Typically you should just be starting fires.
Seeing how many ruined signs you have I would say, you are not that close to stable settings. Slow everything down. When you have 99% success rates, go deeper, when you can’t go deeper, go slightly faster over 20mm/s (cutting) and I would think you are really asking for trouble. Milling basics has my recommendations and they are no where even close to what you are attempting. Best I am comfortable with is 9mm/s 6mmDOC single flute 1/8" upcut in MDF…that is about as hard as wood gets but you can see numbers that I consider reasonable there.
Hi ryan I really dont know where im going wrong im losing steps at 15mms and doc just 1mm im using 2209s with nema 17 2amp in uart mode current set at 1800 in marlin mode
Im running the lowrider 3 8 x4 build woth makita copy router 30000 rpm
Any ideas
