Going with rugged design aluminum 611 plat milled Plastic XY Plates
https://1drv.ms/a/s!AuFirwug-g8_j_QNXj-DKwLfvfX11A
Aluminum 611 plate with a laser! Cool. What kind of aluminum is that?
Its from my old MPCNC hot Bed not sure what type but its very Rigid no flex most of the videos I see them their 611 plate flex when they enter Material i am trying to eliminate that. I have the File from ESTLCAM if you want it the holes on front and back are for 12mm Line Lasers so I can make X at Router Center and X at Laser Center will put on switch for alignment.
I wanted to Use that Trochaidal Milling Bunt my Arduino would just lock up as soon as I tried to run Code.
611_plate-W-LSR-30MMS.zip (39.9 KB)
